GDAL failure in call from java mapscript
Frank Warmerdam
warmerdam at POBOX.COM
Thu Aug 30 17:33:48 EDT 2007
Ben Tuttle wrote:
> Note that the only difference is that the format QS parameter has been
> changed from "image/png" to "image/tiff".
Ben,
I suspect you are running into GDAL bug #1736:
http://trac.osgeo.org/gdal/ticket/1736
In particular this affects applications trying to produce GeoTIFF output
with GDAL in situations with modest sized stacks (ie. JVMs).
If this is the issue, you can upgrade to a 1.4 branch or "svn trunk" snapshot
of GDAL to correct the issue.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
