GDAL failure in call from java mapscript
Ben Tuttle funkbucket at GMAIL.COM
Thu Aug 30 18:33:28 EDT 2007
Thanks Frank and Howard. Increasing the stack size to 512 made the
issue go away as did upgrading our version of GDAL (as per Franks
suggestion) without changing the stack size.
On 8/30/07, Frank Warmerdam <warmerdam at pobox.com> wrote:
> Ben Tuttle wrote:
> > Note that the only difference is that the format QS parameter has been
> > changed from "image/png" to "image/tiff".
> Ben,
> I suspect you are running into GDAL bug #1736:
>   http://trac.osgeo.org/gdal/ticket/1736
> In particular this affects applications trying to produce GeoTIFF output
> with GDAL in situations with modest sized stacks (ie. JVMs).
> If this is the issue, you can upgrade to a 1.4 branch or "svn trunk" snapshot
> of GDAL to correct the issue.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | President OSGeo, http://osgeo.org
