FW: [UMN_MAPSERVER-USERS] MAPSERVER: Implementation Question
Guillaume Sueur guillaume.sueur at NEOGEO-ONLINE.NET
Wed Dec 12 05:29:39 EST 2007
yes it does
Neil Atherton a écrit :
> Does Mapserver work with Oracle Locator?
> -----Original Message-----
> From: Umberto Nicoletti [mailto:umberto.nicoletti at gmail.com]
> Sent: Wednesday, 12 December 2007 8:28 PM
> To: Neil Atherton
> Subject: Re: [UMN_MAPSERVER-USERS] MAPSERVER: Implementation Question
> I've used Spatial in the past, so that I'm sure it will work.
> Locator is the trimmed down version of Spatial shipped with XE,
> standard, etc. Dunno if it works with mapserver but I suspect it
> should.
> Umberto
> On Dec 12, 2007 10:22 AM, Neil Atherton <Neil.Atherton at lmal.com.au> wrote:
>> Do you need Oracle Spatial or is Locator enough?  Locator comes standard with Oracle, but you pay extra for Spatial.
>> Sent: Wednesday, 12 December 2007 8:03 PM
>> To: Neil Atherton
>> Cc: MAPSERVER-USERS at lists.umn.edu
>> Neil,
>> if you already have all of your data in an Oracle database and you
>> have the license for oracle spatial then the simplest solution is to
>> use the Oracle spatial extensions.
>> In this way you can create spatial objects (points, polygons, lines,
>> etc) out of your data and then query them with mapserver directly.
>> Mapserver could first apply a filter (say what's that cost>3000 and
>> cost<6000) and then run the spatial query (say what's inside a
>> shape/rect drawn with the user interface).
>> HTH,
>> Umberto
>> On Dec 12, 2007 4:49 AM, Neil Atherton <Neil.Atherton at lmal.com.au> wrote:
>>> Hello All,
>>> I am currently part of a team developing a Task/Production Management/Work
>>> Flow Management application for a client here in Australia.  The core of
>>> this application is the concept of a "task", which is basically a set of
>>> requirements that come in from customers (our client's customers) and are
>>> passed around the organisation.  The result of a task is one or more
>>> "products", which are what is built in response to the customer
>>> requirements.  Both tasks and products have a geospatial component, in that
>>> they have coordinates stored against them.
>>> We have been asked to use Oracle as the DBMS and to build our application on
>>> top of TRIM.
>>> I have requirements to build a map search interface.  They want a map that
>>> they can draw a bounding box on and have the application return all tasks
>>> and products that fall within that area.  That geospatial search can also be
>>> combined with a textual search (e.g. date ranges, product author etc).
>>> That should be enough background...
>>> One of the solutions I've been looking at is Mapserver.  The web site says
>>> that data can be added via a delimited text file, and I think I've found
>>> examples of applications that use an index file to query against.  I had
>>> envisioned something like the following implementation:
>>>  *        An index file (or files) is built when products/tasks are stored
>>>  o   This index file lists all products/tasks against a set of coordinates -
>>> it would be as simple as product/task number vs. coordinates.
>>>  *        The user draws a bounding box on the map search interface deployed
>>> via Mapserver
>>>  *        A query is made against the index file(s)
>>>  *        The returned product/task numbers are passed to TRIM
>>>  *        TRIM joins this search result with any other search criteria (e.g.
>>> date, author, title etc)
>>>  *        TRIM executes this joined query
>>>  *        The results can be returned to Mapserver somehow, so the user can
>>> see them graphically (e.g. a flag at each of the product/task locations)
>>> Does that sound sensible or is it too simplistic?  Our application really is
>>> light-on when it comes to GIS content, and the other solutions I'm looking
>>> at (e.g. ArcIMS/ArcSDE, Dekho/ArcGIS Server) look to be overkill.
>>> Thank you for your time,
>>> Neil
>>> Neil Atherton
>>>  Principal Engineer
>>>  Lockheed Martin Australia Information Systems and Global Services (IS&GS),
>>>  a division of Lockheed Martin Australia Pty Limited
>>>  Ph: 0419 035 319
>>>  ________________________________
>>>  This email and any files transmitted with it are intended solely for the
>>> use of the individual or entity to whom they are addressed. They may contain
>>> sensitive and/or inconfidence information that is LMAL proprietary
>>> information
>> This email and any files transmitted with it are intended solely for the use of the individual or entity to whom they are addressed. They may contain sensitive and/or inconfidence information that is LMAL proprietary information
Guillaume SUEUR
Expert SIG et OpenSource
NEOGEO
46 RUE MATABIAU
31000 TOULOUSE
06 65 58 88 82
Site web : http://www.neogeo-online.net
