Activate MrSid support using Gdal - Ubuntu Feisty
Steven De Vriendt
gisaalter at GMAIL.COM
Wed Dec 12 10:45:35 EST 2007
Thanks for clearing that up Frank !
I will try to convert my image as you suggest, do you have any suggestions
of the format to use ? I have the experience when I try to convert my image
(±258mb) that it just blows up the size of the image into gigabytes...Thanks
for helping out !
Steven
On Dec 12, 2007 4:39 PM, Frank Warmerdam <warmerdam at pobox.com> wrote:
> Steven De Vriendt wrote:
> > Hi list,
> > I have installed gdal-bin using the synaptic manager in ubuntu feisty.
> Yet,
> > when I try to use gdalinfo on my sid-file, I get a format unsupported
> > message.
> > How can activate mrsid support ?
> Steven,
> It is in theory possible to build the GDAL MrSID driver as a plugin and
> use
> it with your installed GDAL. But this is tricky, and it will only work if
> there is a MrSID DSDK available that is compatible with the
> OS/architecture
> and compiler version your GDAL is built for. If you want to pursue that
> path ... good luck.
> Alternatively, you could install FWTools and just use it for the specific
> translation of the mrsid's into something more generally useful.
> http://fwtools.maptools.org/
> Because the MrSID DSDK is proprietary software, provided only in
> pre-compiled format it is challenging to offer it in free software
> distributions.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam<http://pobox.com/%7Ewarmerdam>
> and watch the world go round - Rush | President OSGeo, http://osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20071212/17f6943e/attachment.html
