Layer reprojection in WFS Server
Rodrigo Martín LÓPEZ GREGORIO
rodrigomlg at GMAIL.COM
Thu Dec 13 09:56:18 EST 2007
Sorry people. Problem Solved.
After several time trying to get it working I sent the mail to the list and
after that I figure out what the problem was. I was setting wrong the EXTENT
in my map... I was exchanging the lat and long so the map extent was wrong
and there was no reprojected points in the map extent area.
Sorry again.
Rodrigo.
On Dec 13, 2007 1:51 PM, Rodrigo Martín LÓPEZ GREGORIO <rodrigomlg at gmail.com>
wrote:
> Hi List.
> I'm trying to serve some point layers using mapserver as WFS server. I
> want to serve this layers in EPSG:4326, but my layers (stored in postgres)
> are in EPSG:22195.
> I tried several things (like setting EPSG:4326 PROJECTION at map level and
> EPSG:22195 at layer level, working with "wfs_srs" at map and layer level,
> etc) but I get always a <gml:null>missing</gml:null> as answer from server.
> I'm working on windows, and I tested it with different versions of ms4w
> (including the actual version), with the same result in all the tests.
> I also tried setting DEBUG ON in my map file, but no errors are reported
> in the error.log file.
> I followed the "WFS Servers with MapServer" howto and I get it working in
> EPSG:22195 coordinates but no in EPSG:4326.
> Is there something I'm missing? Somewere I read that Mapserver WFS Server
> can't reproject layers. Is that right?
> Thanks in advance.
> Rodrigo.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20071213/72d15314/attachment.html
