Data only projected in some region
Tran, Toan (MCYS)
Toan.Tran at ONTARIO.CA
Thu Dec 13 12:32:02 EST 2007
This is a little hard to describe, but are there any reason why when
using epsg: 42304 in PROJECTION (both MAP and LAYER level),
only the points in a specific area appear in the map?
For example, I am viewing the Toronto area now on the map and I see 4
points (1,0 2,0 3,0 4,0). I know there are more points to the east
(i.e. 5,0) based on the data store in a CSV file, but if I pan toward
the east, these points (5,0) will now show up.
Attached is the config.map file and image file.
Thanks
Toan
Type: application/octet-stream
Desc: config.map
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20071213/be4f650e/config.obj
Type: application/msword
Desc: pic.doc
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20071213/be4f650e/pic.doc
