mapserver 5 parallel to mapserver 4?
Piero Cavalieri
Piero.Cavalieri at HEIDI.IT
Mon Dec 17 04:27:49 EST 2007
I think, if you use mapserver in cgi mode, u could simply make calls to different paths, for example you could install mapsevrer 4 and 5 in different folders under the Scripts (or cgi-bin) directory, then make calls like:
http://localhost/Scripts/mapserver4/mapserv.exe?map=....
http://localhost/Scripts/mapserver5/mapserv.exe?map=....
Maybe this works, eventually pay attention to environment variables (if u need for mapserver).
Cheers
Piero
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of R. Ortner
Sent: lunedì 17 dicembre 2007 8.14
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] mapserver 5 parallel to mapserver 4?
I have mapserver 4.10 on my system and I´d like to install mapserver 5.
Is it possible to install the new version parallel to the old one? and if
how?
Is there a mapserver 5 binary for slackware linux available?
thx
View this message in context: http://www.nabble.com/mapserver-5-parallel-to-mapserver-4--tp14370113p14370113.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
