AGG output and WMS inimage error message bug?
Pål Kristensen pal.kristensen at STATKART.NO
Mon Dec 17 08:59:44 EST 2007
Hi!
OK, I'll do that tomorrow
Regards,
Pål Kristensen
Daniel Morissette-2 wrote:
> Sounds like a real bug that needs fixing. Could one of you please file a
> ticket in Trac about it?
> Daniel
> Shawn Gervais wrote:
>>> When using AGG renderer in output format and inimage as WMS error
>>> message
>>> type, mapserver does not return any error message when an error
>>> occurs, only
>>> the requested URL. And even more severe is that the returned
>>> information is
>>> a text string, and not an image.
>>> If I switch to GD output in the exact same service and the exact same
>>> mapfile, mapservere behaves correctly.
>>> Can anyone confirm this behavior/bug, or tell me if there is some
>>> parameters
>>> or keywords that needs to be set to correct the problem?
>> Hi Pål,
>> I had the same issue - the way that I fixed it was by ensuring that the
>> OUTPUTFORMAT blocks for gd/png and gd/gif were defined in my mapfile. I
>> believe that mapserver uses GD to do the error-in-image stuff, even if
>> you normally use AGG to render your maps.
>> By the way, the behavior you describe where mapserver returns the
>> requested URL instead of an image is actually a byproduct of how Firefox
>> handles broken images. MapServer does indeed return an image (or part of
>> one), but it's broken.
>> -Shawn
> Daniel Morissette
> http://www.mapgears.com/
View this message in context: http://www.nabble.com/AGG-output-and-WMS-inimage-error-message-bug--tp14332634p14370303.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
