mapserver 5 parallel to mapserver 4?
Gregor Mosheh
gregor at HOSTGIS.COM
Mon Dec 17 14:27:19 EST 2007
Piero Cavalieri wrote:
> in cgi mode, u could simply make calls to different paths
> http://localhost/Scripts/mapserver4/mapserv.exe?map=....
> http://localhost/Scripts/mapserver5/mapserv.exe?map=....
That doesn't address the many other binaries, nor MapScripts. For
instance, if you wanted shp2img or PHP/MapScript, you'd have to take
some care about how to install them.
But if you just wanted to try out the CGI for a trial, and not use
MapScript, this trick should work A-OK.
In fact, you wouldn't even need to install them to different paths, just
different names, e.g. /cgi-bin/mapserv5 and /cgi-bin/mapserv
Gregor Mosheh / Greg Allensworth
System Administrator, HostGIS cartographic development & hosting services
http://www.HostGIS.com/
"Remember that no one cares if you can back up,
only if you can restore." - AMANDA
