[UMN_MAPSERVER-USERS] ./configuration problem
JS Ubei
jsubei at YAHOO.FR
Tue Dec 18 05:37:31 EST 2007
Do you have GD installed (Or AGG since mapserver 5) ?
In my case, I dont need no another options, for my CENTOS 5 build of a nightbuild of mapserver 5 :
#installation of GD library ...
yum install gd-devel
#[... here installation of proj4, gdal, swig, ...]
#And mapserver :
wget http://download.osgeo.org/mapserver/nightly.tar.gz
tar xzf nightly.tar.gz
cd mapserver_dev/
ln -s /usr/lib/libgif.so.4 /usr/lib/libgif.so
ln -s /usr/lib/libpng.so.3 /usr/lib/libpng.so
./configure --with-wfs --with-wfsclient --with-wmsclient --with-wms --with-proj=/usr/local --with-ogr=/usr/local/bin/gdal-config --with-gdal=/usr/local/bin/gdal-config --with-postgis --with-curl-config=/usr/bin/curl-config --with-geos=/usr/bin/geos-config --with-pdf=/usr/local --with-threads
make
----- Message d'origine ----
De : R. Ortner <reinhard.ortner at EDU.FH-KAERNTEN.AC.AT>
À : MAPSERVER-USERS at LISTS.UMN.EDU
Envoyé le : Mardi, 18 Décembre 2007, 11h01mn 40s
Objet : [UMN_MAPSERVER-USERS] ./configuration problem
I´m trying to install mapserver 5 on my slackware linux.
when I run the ./configuration without any optional settings, the jpeg
support is -DUSE_JPEG.
But when I try to add some options like:
--with-postgis=/usr/bin/pg_config
--with-gdal=/usr/bin/gdal-config --with-ogr=/usr/bin/gdal-config \
the jpeg support is empty.
when i try to add jpeg with --with-jpeg there is still no jpeg enabled
the same with the png support
how do I have to specify this settings for jpeg and png?
thx for help
regards
R.Ortner
View this message in context:
http://www.nabble.com/.-configuration-problem-tp14389894p14389894.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
_____________________________________________________________________________
Ne gardez plus qu'une seule adresse mail ! Copiez vos mails vers Yahoo! Mail http://mail.yahoo.fr
