./configuration problem
R. Ortner
reinhard.ortner at EDU.FH-KAERNTEN.AC.AT
Tue Dec 18 05:42:14 EST 2007
yes, gd is installed:
gd
GD Support enabled
GD Version bundled (2.0.34 compatible)
FreeType Support enabled
FreeType Linkage with freetype
FreeType Version 2.1.9
GIF Read Support enabled
GIF Create Support enabled
JPG Support enabled
PNG Support enabled
WBMP Support enabled
XBM Support enabled
> Von: JS Ubei [mailto:jsubei at yahoo.fr]
> Gesendet: Di 18.12.2007 11:37
> An: Ortner Reinhard; MAPSERVER-USERS at LISTS.UMN.EDU
> Betreff: Re : [UMN_MAPSERVER-USERS] ./configuration problem
> Do you have GD installed (Or AGG since mapserver 5) ?
> In my case, I dont need no another options, for my CENTOS 5 build of a
> nightbuild of mapserver 5 :
> #installation of GD library ...
> yum install gd-devel
> #[... here installation of proj4, gdal, swig, ...]
> #And mapserver :
> wget http://download.osgeo.org/mapserver/nightly.tar.gz
> tar xzf nightly.tar.gz
> cd mapserver_dev/
> ln -s /usr/lib/libgif.so.4 /usr/lib/libgif.so
> ln -s /usr/lib/libpng.so.3 /usr/lib/libpng.so
> ./configure --with-wfs --with-wfsclient --with-wmsclient --with-wms
> --with-proj=/usr/local --with-ogr=/usr/local/bin/gdal-config
> --with-gdal=/usr/local/bin/gdal-config --with-postgis
> --with-curl-config=/usr/bin/curl-config --with-geos=/usr/bin/geos-config
> --with-pdf=/usr/local --with-threads
> make
> author="R. Ortner">
> Hi,
> I´m trying to install mapserver 5 on my slackware linux.
> when I run the ./configuration without any optional settings, the jpeg
> support is -DUSE_JPEG.
> But when I try to add some options like: --with-postgis=/usr/bin/pg_config
> --with-gdal=/usr/bin/gdal-config --with-ogr=/usr/bin/gdal-config \
> the jpeg support is empty.
> when i try to add jpeg with --with-jpeg there is still no jpeg enabled
> the same with the png support
> how do I have to specify this settings for jpeg and png?
> thx for help
> regards
> R.Ortner
View this message in context: http://www.nabble.com/.-configuration-problem-tp14389894p14391876.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
