./configuration problem
Daniel Morissette dmorissette at MAPGEARS.COM
Tue Dec 18 11:43:06 EST 2007
The -DUSE_JPEG flag refers to supporting JPEG as an *input* format and
has nothing to do with generating map output to JPEG format.
When you include GDAL then you do not need -DUSE_JPEG because GDAL
already provides support for reading this format and more advanced
raster processing features, that's why -DUSE_JPEG is disabled by the
configure script.
Daniel
R. Ortner wrote:
> Hi,
> I´m trying to install mapserver 5 on my slackware linux.
> when I run the ./configuration without any optional settings, the jpeg
> support is -DUSE_JPEG.
> But when I try to add some options like: --with-postgis=/usr/bin/pg_config
> --with-gdal=/usr/bin/gdal-config --with-ogr=/usr/bin/gdal-config \
> the jpeg support is empty.
> when i try to add jpeg with --with-jpeg there is still no jpeg enabled
> the same with the png support
> how do I have to specify this settings for jpeg and png?
> thx for help
> regards
> R.Ortner
Daniel Morissette
http://www.mapgears.com/
