mapserver update
R. Ortner
reinhard.ortner at EDU.FH-KAERNTEN.AC.AT
Wed Dec 19 03:36:54 EST 2007
I have Mapserver 4.10 installed and tried to install the mapserver 5.0.0.
I´ve configured the mapserver with
./configure --with-ogr=/usr/bin/gdal-config --with-wfs --with-proj
--with-postgis --with-gdal --with-geos --with-wmsclient --with-wcs
--with-sos --with-php=/usr/include/php/main/ --with-threads
and then executed the make command.
after copying the mapserv file to my cgi-bin folder where the old one (from
mapserver 4) was I thougtt that I now have mapserver 5 installed, but when I
call the test.php which shows me what version is installed, it tells me
still Mapserver 4.10.
Is there something special to do to activate the mapserver 5 (i thought with
installing the version 4 the old version should be either overwritten or
working parallel by calling the new mapserv or the old mapserv (which I
copied to a subfolder (mapserver4/mapserv).
regards
View this message in context: http://www.nabble.com/mapserver-update-tp14412963p14412963.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
