mapserver update
R. Ortner reinhard.ortner at EDU.FH-KAERNTEN.AC.AT
Wed Dec 19 04:07:01 EST 2007
I tried to replace my /usr/lib/php/extensions/php_mapscript.so but in the
mapserver5 folder (downloaded from
http://mapserver.gis.umn.edu/download/current/) is no php_mapserver.so in
the /mapserver/php3 folder!?
Umberto wrote:
> In fact now you have the *CGI* version of mapserver installed. But
> since you use php mapscript you need to configure, compile and install
> php mapscript.
> You should be able to do that just by:
> mapserver-5-source$ cd mapscript/php3
> mapserver-5-source$ make
> and then replace with the new php_*.so the old ones picked up in php.ini
> HTH,
> Umberto
> Hi,
> I have Mapserver 4.10 installed and tried to install the mapserver 5.0.0.
> I´ve configured the mapserver with
> ./configure --with-ogr=/usr/bin/gdal-config --with-wfs --with-proj
> --with-postgis --with-gdal --with-geos --with-wmsclient --with-wcs
> --with-sos --with-php=/usr/include/php/main/ --with-threads
> and then executed the make command.
> after copying the mapserv file to my cgi-bin folder where the old one
> (from mapserver 4) was I thougtt that I now have mapserver 5 installed,
> but when I call the test.php which shows me what version is installed, it
> tells me still Mapserver 4.10.
> Is there something special to do to activate the mapserver 5 (i thought
> with installing the version 4 the old version should be either overwritten
> or working parallel by calling the new mapserv or the old mapserv (which I
> copied to a subfolder (mapserver4/mapserv).
> regards
View this message in context: http://www.nabble.com/mapserver-update-tp14412963p14413075.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
