mapserver update
Guillaume Sueur guillaume.sueur at NEOGEO-ONLINE.NET
Wed Dec 19 03:48:34 EST 2007
You are making a confusion between mapserver cgi and the php mapscript
module.
You have placed mapserv (cgi version) in cgi-bin, it is so the one which
is used if you use cgi and it shoulb be version 5
The phpinfo() stuff tells you about which mapscript is installed.
Obviously you didn't update that one by copying the
mapscript/php3/php_mapscript.so from your mapserver build directory to
your php extensions dir.
Regards,
Guillaume
R. Ortner a écrit :
> Hi,
> I have Mapserver 4.10 installed and tried to install the mapserver 5.0.0.
> I´ve configured the mapserver with
> ./configure --with-ogr=/usr/bin/gdal-config --with-wfs --with-proj
> --with-postgis --with-gdal --with-geos --with-wmsclient --with-wcs
> --with-sos --with-php=/usr/include/php/main/ --with-threads
> and then executed the make command.
> after copying the mapserv file to my cgi-bin folder where the old one (from
> mapserver 4) was I thougtt that I now have mapserver 5 installed, but when I
> call the test.php which shows me what version is installed, it tells me
> still Mapserver 4.10.
> Is there something special to do to activate the mapserver 5 (i thought with
> installing the version 4 the old version should be either overwritten or
> working parallel by calling the new mapserv or the old mapserv (which I
> copied to a subfolder (mapserver4/mapserv).
> regards
