MAPSERVER-USERS Digest - 26 Dec 2007 to 27 Dec 2007 (#2007-353)
Nelson Guda nelsong at MAIL.UTEXAS.EDU
Fri Dec 28 09:41:32 EST 2007
Hi Tom,
Thanks for your reply.  The mapfile is to serve the WFS layers
directly from the data.
I have the DATA connection defined in the layer as:	DATA
ira_by_name_nad83
where "ira_by_name_nad83" is the name of the shapefile.  And I have
the shapepath at the head of the mapfile as: SHAPEPATH "../shapefiles"
As it is, the shapepath is relative to the mapfile.  Should it be
relative to the mapserv cgi?
I also noticed that the CONNECTION was incorrectly defined and fixed
it.  After I did that, running the test query took a long time, but
still returned a null result (for a point that should return something).
Also, how do you define a bbox in a wfs query?  Can you put it before
the <Filter> in standard wms query style?
thanks much,
nelson
On Dec 28, 2007, at 12:01 AM, MAPSERVER-USERS automatic digest system
wrote:
> There are 4 messages totalling 436 lines in this issue.
> Topics of the day:
>   1. WFS mapserver
>   2. World Files - Defining Image Rotation
>   3. Reprojection issue (kind of solved)
>   4. Legends and setting fonts for . . .
> Date:    Thu, 27 Dec 2007 07:37:29 -0500
> From:    "Kralidis,Tom [Burlington]" <Tom.Kralidis at EC.GC.CA>
> Subject: Re: WFS mapserver
> Is the mapfile below meant to serve the WFS layers directly from the
> data?  Or connect to remote WFS layers?  If the former, then you
> need to
> define the data connection (i.e. shapefile, OGR, etc.).  If the
> latter,
> then you need to correctly define your host in CONNECTION, which
> currently does not resolve.
> ..Tom
