Labels and MINFEATURESIZE
Steve Lime Steve.Lime at DNR.STATE.MN.US
Thu Feb 1 11:02:48 EST 2007
Can you whip up a test case (data and mapfile)?
Steve
>>> Sture Dingsøyr <candalt at online.no> 2/1/2007 4:56:19 AM >>>
Hi again...
I have tried to enter the LABELCACHE OFF to my layer and removed the MINFEATURESIZE, but still not all of the features are labeled...strange... Have tested the data in ArcView...so i think i can rule-out errors in the data..
By default there is no limit on how big a feature is, at least I don't believe there is. So it is not necessary
to set the MINFEATURESIZE parameter. Out of curiosity what happens if you at LABELCACHE OFF to
the layer object below. That *should * label everything drawn. No collision avoidance will happen then
but at least we can see what is and isn't being labeled.
Steve
>>> Sture Dingsøyr <candalt at ONLINE.NO> 1/26/2007 1:53 AM >>>
Hi there...
I have a polygon layer that on high scales only is visible in the map (gif output) as very small areas (maybe as a single pixel). This is fine, but i want to put a label on every polygon regardless of how small they are.
I have tried putting a label on my class with the MINFEATURESIZE parameter but with no luck. The parameter (MINFEATURESIZE) seems to be working, cause if i set i to e.g. 20 my polygons do not get labled until the scale is smaller.
Is there a way to force labels on a polygon layer regardless of how "small" the polygons are?
My layer definition below:
LAYER
	DATA "test"
	LABELITEM "NAME"
	STATUS on
	TYPE polygon
	NAME "test"
	CLASS
		COLOR 255 0 0
		MAXSCALE 100000000
		MINSCALE 0
		NAME "Test"
  		LABEL
  			ANTIALIAS True
  			FONT "arial"
  			TYPE truetype
  			SIZE 7
  			COLOR 0 0 0
  			OUTLINECOLOR 255 255 255
  			OFFSET 0 0
  			POSITION cc
  			PARTIALS false
  			FORCE true
  			MINFEATURESIZE 1
  		END
	END
END
Regards Sture :-)
