Labels and MINFEATURESIZE
Rodrigo Martín LÓPEZ GREGORIO rodrigomartin at LOPEZGREGORIO.COM.AR
Thu Feb 1 11:35:46 EST 2007
Hi, I'm not sure if I understand what you are trying to do. But if you want
to label polygons no matter how small they are, I think you must just remove
the MINFEATURESIZE from your LABEL, then the label will be drawed always.
I'm not sure if this is what you are looking for but I think it is.
Rodrigo.
On 2/1/07, Steve Lime <Steve.Lime at dnr.state.mn.us> wrote:
> Can you whip up a test case (data and mapfile)?
> Steve
> >>> Sture Dingsøyr <candalt at online.no> 2/1/2007 4:56:19 AM >>>
> Hi again...
> I have tried to enter the LABELCACHE OFF to my layer and removed the
> MINFEATURESIZE, but still not all of the features are labeled...strange...
> Have tested the data in ArcView...so i think i can rule-out errors in the
> data..
> By default there is no limit on how big a feature is, at least I don't
> believe there is. So it is not necessary
> to set the MINFEATURESIZE parameter. Out of curiosity what happens if you
> at LABELCACHE OFF to
> the layer object below. That *should * label everything drawn. No
> collision avoidance will happen then
> but at least we can see what is and isn't being labeled.
> Steve
> >>> Sture Dingsøyr <candalt at ONLINE.NO> 1/26/2007 1:53 AM >>>
> Hi there...
> I have a polygon layer that on high scales only is visible in the map (gif
> output) as very small areas (maybe as a single pixel). This is fine, but i
> want to put a label on every polygon regardless of how small they are.
> I have tried putting a label on my class with the MINFEATURESIZE parameter
> but with no luck. The parameter (MINFEATURESIZE) seems to be working, cause
> if i set i to e.g. 20 my polygons do not get labled until the scale is
> smaller.
> Is there a way to force labels on a polygon layer regardless of how
> "small" the polygons are?
> My layer definition below:
> LAYER
>         DATA "test"
>         LABELITEM "NAME"
>         STATUS on
>         TYPE polygon
>         NAME "test"
>         CLASS
>                 COLOR 255 0 0
>                 MAXSCALE 100000000
>                 MINSCALE 0
>                 NAME "Test"
>                 LABEL
>                         ANTIALIAS True
>                         FONT "arial"
>                         TYPE truetype
>                         SIZE 7
>                         COLOR 0 0 0
>                         OUTLINECOLOR 255 255 255
>                         OFFSET 0 0
>                         POSITION cc
>                         PARTIALS false
>                         FORCE true
>                         MINFEATURESIZE 1
>                 END
>         END
> END
> Regards Sture :-)
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070201/1d35b6cb/attachment.html
