non-square shapefiles and tileindex
Ara.T.Howard ara.t.howard at NOAA.GOV
Sun Feb 4 02:23:56 EST 2007
On Sat, 3 Feb 2007, Frank Warmerdam wrote:
> Ara,
> Yes, I do that frequently.  Note that all items from the tileindex that
> touch the map request area *are* rendered.
huh.  that's not what i'm seeing, so i've probably made a mistake.
for instance, if you make this request,20,180,30&Format=png
you'll see only one orbit in the image.  this is odd since every orbit crosses
this area.  the orbit shown is the __first__ orbit which crosses the area.
the mapfile i'm using is here
the script here
and all data, including shapfiles, here
have i made an error in my mapfile?  all images are in the tileindex file and
all images contain data in the requested area.  still, only one is rendered?
kind regards.
we can deny everything, except that we have the possibility of being better.
simply reflect on that.
- the dalai lama
