feature-id in getfeatureinfo requests
Daniel Morissette
dmorissette at MAPGEARS.COM
Mon Feb 5 11:12:45 EST 2007
Or pehaps try
METADATA
"gml_featureid" "_index"
END
as suggested in bug 1413, comment #1:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1413#c1
I don't think this is mentioned anywhere in the docs, if this really
works then a note about this should be added to the gml_featureid defn'
at
http://mapserver.gis.umn.edu/docs/howto/wfs_server/?searchterm=gml_featureid
Daniel
Bart van den Eijnden (OSGIS) wrote:
> Ah right, and how about:
> gml_featureid "oid"
> If this does not work, can you post your DATA statement?
> Best regards,
> Bart
> OSGIS, Open Source GIS
> http://www.osgis.nl
> --------- Oorspronkelijk bericht --------
> Van: Richard Duivenvoorde <rdmailings at duif.net>
> Naar: Bart van den Eijnden OSGIS <bartvde at OSGIS.NL>,
> MAPSERVER-USERS at LISTS.UMN.EDU <MAPSERVER-USERS at LISTS.UMN.EDU>
> Onderwerp: Re: [UMN_MAPSERVER-USERS] feature-id in getfeatureinfo requests
> Datum: 05/02/07 13:25
>> Hi Bart,
>> Thanks for the quick response :-)
>> I tried that already, but in the text output, I see ALL columns of the
>> table (though not the 'oid' as a normal 'attribute') in the output. But
>> there is this line:
>> 'Feature 17246'
>> Which IS the oid/feature_id....
>> In the gml I also receive ALL columns in the output, but NO reference to
>> this 17246 oid/feature_id/id...
>> I tried all these:
>> "ows_include_items" "all"
>> "gml_include_items" "all"
>> "wms_include_items" "all"
>> is the oid-column not an official attribute column or something like that?
>> Richard
>> > Hi Richard,
>> > you need to add
>> > GML_INCLUDE_ITEMS "all"
>> > to your LAYER's METADATA section.
>> > Best regards,
>> > Bart
>> > http://www.osgis.nl
>> > Van: Richard Duivenvoorde <rdmailings at DUIF.NET>
>> > Naar: MAPSERVER-USERS at LISTS.UMN.EDU
>> > Onderwerp: [UMN_MAPSERVER-USERS] feature-id in getfeatureinfo
> requests
>> > Datum: 05/02/07 13:01
>> >> Hi All,
>> >> busy using getfeatureinfo from a postgresql/postgis layer.
>> >> Mapserver version 4.8.3 (...)
>> >> Postgresql-table is a point table and has a oid column (create
> script
>> >> with 'WITH OIDS').
>> >> I managed to get the getfeatureinfo up and running, but stumble
> upon the
>> >> missing (feature)-id in the gml output:
>> >> When I do an info format of 'text/plain' I'll receive something
> like:
>> >> GetFeatureInfo results:
>> >> Layer 'testpoints'
>> >> Feature 17246:
>> >> bla = 'zyz'
>> >> foo= ''
>> >> but when i ask for 'application/vnd.ogc.gml' as info format I
> receive
>> >> gml without the feature-id (not even as a normal 'oid'
> property??):
>> >> &lt;?xml version=&quot;1.0&quot;
> encoding=&quot;ISO-8859-1&quot;?&gt;
>> >> &lt;msGMLOutput
>> >> xmlns:gml=&quot;http://www.opengis.net/gml&quot;
>> >> xmlns:xlink=&quot;http://www.w3.org/1999/xlink&quot;
> xmlns:xsi=&quot;http://www.w3.org/2001/XMLSchema-instance&quot;&gt;
>> >> &lt;testpoints_layer&gt;
>> >> &lt;testpoints_feature&gt;
>> >> &lt;gml:boundedBy&gt;
>> >> &lt;gml:Box
> srsName=&quot;EPSG:28992&quot;&gt;
>> >> &lt;gml:coordinates&gt;67349.250981,549785.660401
>> >> 67349.250981,549785.660401&lt;/gml:coordinates&gt;
>> >> &lt;/gml:Box&gt;
>> >> &lt;/gml:boundedBy&gt;
>> >> &lt;bla&gt;zyz&lt;/bla&gt;
>> >> &lt;foo&gt;&lt;/foo&gt;
>> >> &lt;/testpoints_feature&gt;
>> >> &lt;/testpoints_layer&gt;
>> >> &lt;/msGMLOutput&gt;
>> >> Am I missing some metadata property in my mapfile? I would expect
> either
>> >> a feature-id attribute in the testpoints_feature element, OR
> oid-element
>> >> as child of the testpoints_feature element.
>> >> TIA,
>> >> Richard
Daniel Morissette
http://www.mapgears.com/
