feature-id in getfeatureinfo requests
Richard Duivenvoorde
rdmailings at DUIF.NET
Mon Feb 5 11:55:39 EST 2007
Thanks Daniel,
but
Nope, tried and failed :-(
Maybe it has something to do with the way I created the table:
CREATE TABLE testpoints
waarnemer character varying(40),
plaats character varying(40),
soort character varying(40),
aantal integer,
aantal2 character varying(40),
opmerking character varying(200),
the_geom geometry,
CONSTRAINT testpoints_pkey PRIMARY KEY (oid),
CONSTRAINT enforce_dims_the_geom CHECK (ndims(the_geom) = 2),
CONSTRAINT enforce_geotype_the_geom CHECK (geometrytype(the_geom) =
'POINT'::text OR the_geom IS NULL),
CONSTRAINT enforce_srid_the_geom CHECK (srid(the_geom) = 28992)
WITH OIDS;
ALTER TABLE testpoints OWNER TO postgres;
I wanted to have a table in which I had an auto incrementing id-column.
This was the way to do that (according to mr Google :-) )
If I look at the table with pgAdmin III there is a column 'oid' with the
id's in it. If I look with QGIS there is a column 'id'...
But if I do:
SELECT
a.attnum,
a.attname AS field,
t.typname AS type,
a.attlen AS length,
a.atttypmod AS lengthvar,
a.attnotnull AS notnull
FROM
pg_class c,
pg_attribute a,
pg_type t
WHERE
c.relname = 'testpoints'
and a.attnum > 0
and a.attrelid = c.oid
and a.atttypid = t.oid
ORDER BY a.attnum
I don't see the oid column either....
It probably has something to do with the special meaning of an oid
column in postgresql???
I will try to update my mapserver to the newest version (working with
4.8.3 now...) and see if that works.
Other solution: add my own id's of use a sequence instead of this
autoincrementing... Any postgresql guru's around?
Thanks, Richard
Daniel Morissette wrote:
> Or pehaps try
> METADATA
> "gml_featureid" "_index"
> END
> as suggested in bug 1413, comment #1:
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1413#c1
> I don't think this is mentioned anywhere in the docs, if this really
> works then a note about this should be added to the gml_featureid defn'
> at
> http://mapserver.gis.umn.edu/docs/howto/wfs_server/?searchterm=gml_featureid
> Daniel
> Bart van den Eijnden (OSGIS) wrote:
>> Ah right, and how about:
>> gml_featureid "oid"
>> If this does not work, can you post your DATA statement?
>> Best regards,
>> Bart
>> OSGIS, Open Source GIS
>> http://www.osgis.nl
>> --------- Oorspronkelijk bericht --------
>> Van: Richard Duivenvoorde <rdmailings at duif.net>
>> Naar: Bart van den Eijnden OSGIS <bartvde at OSGIS.NL>,
>> MAPSERVER-USERS at LISTS.UMN.EDU <MAPSERVER-USERS at LISTS.UMN.EDU>
>> Onderwerp: Re: [UMN_MAPSERVER-USERS] feature-id in getfeatureinfo
>> requests
>> Datum: 05/02/07 13:25
>>> Hi Bart,
>>> Thanks for the quick response :-)
>>> I tried that already, but in the text output, I see ALL columns of
>>> the table (though not the 'oid' as a normal 'attribute') in the
>>> output. But there is this line:
>>> 'Feature 17246'
>>> Which IS the oid/feature_id....
>>> In the gml I also receive ALL columns in the output, but NO reference
>>> to this 17246 oid/feature_id/id...
>>> I tried all these:
>>> "ows_include_items" "all"
>>> "gml_include_items" "all"
>>> "wms_include_items" "all"
>>> is the oid-column not an official attribute column or something like
>>> that?
>>> Richard
>>> > Hi Richard,
>>> > > you need to add > > GML_INCLUDE_ITEMS "all"
>>> > > to your LAYER's METADATA section.
>>> > > Best regards,
>>> > Bart
>>> > http://www.osgis.nl
>>> > Van: Richard Duivenvoorde <rdmailings at DUIF.NET>
>>> > Naar: MAPSERVER-USERS at LISTS.UMN.EDU
>>> > Onderwerp: [UMN_MAPSERVER-USERS] feature-id in getfeatureinfo
>> requests
>>> > Datum: 05/02/07 13:01
>>> > >> Hi All,
>>> >> busy using getfeatureinfo from a postgresql/postgis layer.
>>> >> Mapserver version 4.8.3 (...)
>>> >> Postgresql-table is a point table and has a oid column (create
>> script
>>> >> with 'WITH OIDS').
>>> >> I managed to get the getfeatureinfo up and running, but stumble
>> upon the
>>> >> missing (feature)-id in the gml output:
>>> >> When I do an info format of 'text/plain' I'll receive something
>> like:
>>> >> GetFeatureInfo results:
>>> >> Layer 'testpoints'
>>> >> Feature 17246:
>>> >> bla = 'zyz'
>>> >> foo= ''
>>> >> but when i ask for 'application/vnd.ogc.gml' as info format I
>> receive
>>> >> gml without the feature-id (not even as a normal 'oid'
>> property??):
>>> >> &lt;?xml version=&quot;1.0&quot;
>> encoding=&quot;ISO-8859-1&quot;?&gt;
>>> >> &lt;msGMLOutput
>>> >> xmlns:gml=&quot;http://www.opengis.net/gml&quot;
>>> xmlns:xlink=&quot;http://www.w3.org/1999/xlink&quot;
>> xmlns:xsi=&quot;http://www.w3.org/2001/XMLSchema-instance&quot;&gt;
>>> >> &lt;testpoints_layer&gt;
>>> >> &lt;testpoints_feature&gt;
>>> >> &lt;gml:boundedBy&gt;
>>> >> &lt;gml:Box
>> srsName=&quot;EPSG:28992&quot;&gt;
>>> >> &lt;gml:coordinates&gt;67349.250981,549785.660401
>>> >> 67349.250981,549785.660401&lt;/gml:coordinates&gt;
>>> >> &lt;/gml:Box&gt;
>>> >> &lt;/gml:boundedBy&gt;
>>> >> &lt;bla&gt;zyz&lt;/bla&gt;
>>> >> &lt;foo&gt;&lt;/foo&gt;
>>> >> &lt;/testpoints_feature&gt;
>>> >> &lt;/testpoints_layer&gt;
>>> >> &lt;/msGMLOutput&gt;
>>> >> Am I missing some metadata property in my mapfile? I would
>>> expect
>> either
>>> >> a feature-id attribute in the testpoints_feature element, OR
>> oid-element
>>> >> as child of the testpoints_feature element.
>>> >> TIA,
>>> >> Richard
