[UMN_MAPSERVER-DEV] Fwd: [UMN_MAPSERVER-USERS] Connector for SQL Server 2005 with Spatial Extensions
Eduardo Patto Kanegae epk.lists at GMAIL.COM
Thu Feb 8 06:05:51 EST 2007
Just for comment, MsSqlSpatial ( http://www.codeplex.com/MsSqlSpatial)
also installs  OGC feature against MS-SQL2005 databases. Currently it
has one native client : SharpMap, but you can also connect using
MapServer ODBC connection ( for point, line or polygon tables) and
then publish WMS/WFS services.
regards,
http://www.webmapit.com.br
On 2/7/07, Umberto Nicoletti <umberto.nicoletti at gmail.com> wrote:
> Hi Derek,
> I am forwarding your email to the mapserver-dev where it'll get the
> attention it needs.
> Regards,
> Umberto
> ---------- Forwarded message ----------
> From: Derek Diamond <derek at diamondsoftwareconcepts.com>
> Date: Feb 2, 2007 12:59 PM
> Subject: [UMN_MAPSERVER-USERS] Connector for SQL Server 2005 with
> Spatial Extensions
> To: MAPSERVER-USERS at lists.umn.edu
> Hello all.
> I have written a connector that works with SQL Server 2005 with the
> SpatialDB spatial extensions.
> I would like to add the connector to the default mapserver build and make it
> part of the solution as freeware.
> Regards
> Derek
