configure crt1.o error on PPC64 RHEL
Doug B ummmmm22 at GMAIL.COM
Fri Feb 9 16:40:00 EST 2007
Hmmm - only some of the -devel packages (like glibc and zlib) have
64-bit rpms even on the CDs, which leaves me wondering if the issue is
with ppc64 RHEL or with MapServer's configure script not understanding
that flavor's structure.
On 2/9/07, Doug B <ummmmm22 at gmail.com> wrote:
> I notice that configure is looking for libfreetype.a and
> libfreetype.so in both /usr/lib and /usr/lib64, but my rpm install of
> libfreetype-devel only put one in /usr/lib.  The rpm install of
> libfreetype included both /usr/lib and /usr/lib64 content, but the
> -devel package seems to only have /usr/lib content.
> Any clues as to what's wrong with this and the other lib install based
> on that information?  libpng-devel is the same way, and I don't see
> any specific 64-bit package names to use.
> I do realize this isn't specific to MapServer, but I'll take help
> anywhere I can get it.  Thanks.
> Doug
> On 2/5/07, Doug B <ummmmm22 at gmail.com> wrote:
> > Well, now configure isn't finding other installed rpms like freetype and libpng:
> > configure: checking where FreeType 2.x is installed...
> > checking for FT_Init_FreeType in -lfreetype... no
> >         freetype-config or libfreetype cannot be found, possibly needed for GD
> > freetype-config is in /usr/bin (in the path), and libfreetype.so and
> > .a are in /usr/lib.  libfreetype.so.6 in /usr/lib64.
> > Details from config.log:
> > configure:4309: checking where FreeType 2.x is installed...
> > configure:4427: checking for FT_Init_FreeType in
> > -lfreetypeconfigure:4457: gcc -o conftest -m64 -fPIC   conftest.c
> > -lfreetype   -lm -lstdc+
> > +  >&5
> > /usr/bin/ld: skipping incompatible
> > /usr/lib/gcc/ppc64-redhat-linux/3.4.6/../../../libfreetype.so when
> > searching for -lfreetype
> > /usr/lib/gcc/ppc64-redhat-linux/3.4.6/../../../libfreetype.a when
> > /usr/bin/ld: skipping incompatible /usr/lib/libfreetype.so when
> > /usr/bin/ld: skipping incompatible /usr/lib/libfreetype.a when
> > /usr/bin/ld: cannot find -lfreetype
> > collect2: ld returned 1 exit status
> > LDFLAGS=-L/usr/lib64 doesn't seem to make a difference either.
> > I apologize for the ignorance I'm displaying here.  I just never had
> > to delve into issues like this on our previous systems, so I'm not
> > sure where to even begin.
> > > Setting CFLAGS environment variable seems to have worked, FWIW.  If
> > > there's a safer mechanism, I'd be happy to use that too.
> > > > Hmmm - gcc -m64 does not report that error.  What's the best way to
> > > > use that flag in configure?
