Custom Projection
Fawcett, David
David.Fawcett at STATE.MN.US
Mon Feb 12 17:16:09 EST 2007
According to the documentation, ANGLE is not available with CFI
MapServer, but I got it to work following the other directions in the
docs. I am using version 4.8.
You definitely need to define projection blocks at the map level and at
the layer level. Before I defined projections, I just got a white image
back.
David.
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Brent Fraser
Sent: Monday, February 12, 2007 3:57 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Custom Projection
Abe,
Try using ANGLE in the map portion of the map file
(http://mapserver.gis.umn.edu/docs/reference/mapfile/mapObj)
Brent Fraser
GeoAnalytic Inc.
Calgary, Alberta
----- Original Message -----
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Monday, February 12, 2007 1:34 PM
Subject: [UMN_MAPSERVER-USERS] Custom Projection
> Hello all,
> Forgive my ignorance on the subject - is there a way to
define a
> custom projection such that it simply applies a rotation
to the map?
> For instance, instead of the map being oriented with the
top as north,
> I need to orient it in a "you are here" fashion. I want
to put the
> entrance of a building at due south.
> First, in general, can this even be done? What I mean to
say is are
> projections even used in this fashion? Second, if it can
be done, how
> does one go about defining a custom projection? Can you
fire up
> ArcGIS and use the GUI? Are there command line tools?
> Thanks for any help.
> -Abe
