Filter help, string expression
Steve Lime Steve.Lime at DNR.STATE.MN.US
Wed Feb 21 12:54:10 EST 2007
MapServer doesn't handle nulls all that well. Various data drivers do
things differently
which complicates things. For example, for some NULL means an empty
string.
Anyway, you might try something like this instead:
FILTERITEM "FENAME"
FILTER /./
This tests to see if there is at least one character in the FENAME
attribute. It should
evaluate faster too.
Steve
>>> Scott Schulthess <scott at TOPOZONE.COM> 2/20/2007 1:14:16 PM >>>
I'm trying to use the filter command in my mapfile make mapserver not
draw a street if one of it's attributes (the street name) is null.
I have tried using this
FILTER ("[FENAME]" != "(NULL)")
That's what it looks like in the dbf file - (NULL) when there is no
name. However it just doesn't draw anything for that layer.
Here's the layer definition and one class
  LAYER
    METADATA
                        "wms_srs"       wmsEPSGNAD83
            END
    NAME "US Streets"
            GROUP US_POINTLINE
    STATUS OFF
    DATA "str"
            PROJECTION
      "init=epsg:4326"
    END
    TILEINDEX "us_streets/county_index"
    TILEITEM "location"
    TYPE LINE
    SIZEUNITS PIXELS
            TRANSPARENCY ALPHA //test
            CLASS
      NAME "US Streets"
      MINSCALE  99001
      MAXSCALE 190000
      STYLE
        SYMBOL "circle"
        COLOR 183 176 169
                        SIZE 4
                        ANTIALIAS TRUE
      END
      STYLE
        SYMBOL "circle"
        COLOR 254 254 254
                        SIZE 2
                        ANTIALIAS TRUE
      END
    END
Tips?
-Scott
