MapServer & IWS 8.0 : Connectiontype WMS
Fabio D'Ovidio dovidio at PLANETEK.IT
Thu Feb 22 09:47:18 EST 2007
Has anyone just compiled MapServer with this change (in mapwms.c) on win32 platmform ?
At the moment I need binaries.
thanks
 Ing. Fabio D'Ovidio
 WebGIS Staff
 Planetek Italia Srl
 via Massaua, 12 - 70123 Bari - Italy
 web : http ://www.planetek.it
 e-mail : dovidio at planetek.it
 Lat/Lon 41° 8' 16''N 16° 50' 40''E
On 22 Feb 2007 at 20:55, Chris Tweedie wrote:
> There has been various discussions on this issue but looks like it still hasnt been resolved.
> Fabio, the fix is minor and requires switching some boolean flags to false on the parameters (to stop the unnecessary encoding)
> If you take a look at mapwms.c its fairly straight forward to resolve and is about 3 line changes. From memory the BBOX, Styles and Layers parameter definately need to be changed to false
> Regards,
> Chris Tweedie
> On Thu, 22 Feb 2007 11:40:13 +0100, "Bart van den Eijnden (OSGIS)" <bartvde at OSGIS.NL> wrote:
> > Hi Fabio,
> > this behaviour is called url encoding, but I believe Mapserver is not
> > doing
> > this completely according to the WMS spec.
> > This post by Keith Pomakis from Cubewerx in the OpenLayers bug system
> > describes the issue nicely:
> > http://trac.openlayers.org/ticket/491
> > So what you should do is open up a bug report for this in Mapserver, as it
> > should not be urlencoding the comma in BBOX.
> > Best regards,
> > Bart
> > Fabio D'Ovidio schreef:
> >> Hi!
> >> I have a problem with mapserver 4.8.3 connectiontype WMS to IWS 8.0
> > (Image
> > Web Server 8.0) on Windows Server 2003 and IIS 6.0
> >> When I set in the layer object this connection :
> >> CONNECTIONTYPE WMS CONNECTION
> > "http://myserver/ecwp/ecw_wms.dll?REQUEST=Getmap&VERSION=1.1.0&SERVICE=WM
> >> S&layers=SUD_PUGLIA&styles=&SRS=EPSG:4326&format=image/png"
> >> the characters "." and "," are trasformed in ASCII Hex code and so the
> > BBOX (that i pass to mapserver request) changes from :
> > BBOX=14.696444805187044,39.710853059558424,18.889601564329261,42.33017784967
> >> 0967
> >> to :
> >> BBOX=14%2E6990953467541%2C39%2E7137634204363%2C18%2E8869510227622%2
> >> C42%2E3272674887931
> >> What can I do ?
> >> Thanks
> >> Fabio
> Chris Tweedie
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070222/12cd50d1/attachment.html
