getFeatureInfo against unique character primary key
Sebastian Schmitz sebastian.schmitz at WHEREGROUP.COM
Fri Feb 23 07:51:16 EST 2007
anybody out there having the need for MapServer being able to serve
getFeatureInfo against unique character primary key columns?
Cheers
Sebastian Schmitz
Bart van den Eijnden (OSGIS) schrieb:
> It's a restriction from Mapserver side.
> You can't change your view SQL so that it has an integer primary key column?
> Best regards,
> Bart
> OSGIS, Open Source GIS
> http://www.osgis.nl
> --------- Oorspronkelijk bericht --------
> Van: Sebastian Schmitz <sebastian.schmitz at WHEREGROUP.COM>
> Naar: MAPSERVER-USERS at LISTS.UMN.EDU <MAPSERVER-USERS at LISTS.UMN.EDU>
> Onderwerp: Re: [UMN_MAPSERVER-USERS] OracleSpatial getFeatureInfo problem
> against unique column containing text
> Datum: 23/02/07 09:32
>> Now what do I do?
>> Is this a restriction from Oracle-side or from MapServer?
>> MapServer I guess?
>> Cheers
>> Sebastian
>> &gt; No this is not possible.
>> &gt;
>> &gt; You need to use an integer for the unique column. It's a requirement.
>> &gt;
>> &gt; Best regards,
>> &gt; Bart
>> &gt;
>> &gt; --
>> &gt; Bart van den Eijnden
>> &gt; OSGIS, Open Source GIS
>> &gt; http://www.osgis.nl
>> &gt;
>> &gt;
>> &gt; --------- Oorspronkelijk bericht --------
>> &gt; Van: Sebastian Schmitz &lt;sebastian.schmitz at WHEREGROUP.COM&gt;
>> &gt; Naar: MAPSERVER-USERS at LISTS.UMN.EDU
> &lt;MAPSERVER-USERS at LISTS.UMN.EDU&gt;
>> &gt; Onderwerp: [UMN_MAPSERVER-USERS] OracleSpatial getFeatureInfo problem
>> &gt; against unique column containing text
>> &gt; Datum: 23/02/07 08:33
>> &gt;
>> &gt;
>> &gt;&gt; Hi,
>> &gt;&gt;
>> &gt;&gt; I have a view in Oracle Spatial 10gR2 with a unique Id, which is
> text.
>> &gt;&gt; MapServer draws the map OK using oraclespatial CONNECTIONTYPE.
>> &gt;&gt; However, MapServer is unable to serve a getFeatureInfo request
> against
>> &gt;&gt; that view. If I change the DATA statement to substr(ID, 3,7),
> removing
>> &gt;&gt; letters from the ID - getFeatureInfo runs fine for the time
> being, but
>> &gt;&gt; without the letters my ID will soon lose its uniqueness.
>> &gt;&gt;
>> &gt;&gt; Is MapServer able to server a getFeatureInfo request against DATA
> that
>> &gt;&gt; uses a unique text-column containing letters?
>> &gt;&gt;
>> &gt;&gt; Find more detail below:
>> &gt;&gt; mapfile:
>> &gt;&gt; ...
>> &gt;&gt; CONNECTIONTYPE oraclespatial
>> &gt;&gt;   CONNECTION &amp;quot;GDI/****@ORCL_HOGGNO&amp;quot;
>> &gt;&gt;   #not serving getFeatureInfo
>> &gt;&gt;   DATA &amp;quot;GEOM FROM V_*** USING UNIQUE SST_NR SRID 8307
> FILTER VERSION
>> &gt;&gt;
>> &gt; 10g&amp;quot;
>> &gt;
>> &gt;&gt;   #serving getFeatureInfo
>> &gt;&gt;   DATA &amp;quot;GEOM FROM V_*** USING UNIQUE substr(SST_NR,3,7)
> SRID 8307
>> &gt;&gt;
>> &gt; FILTER
>> &gt;
>> &gt;&gt; VERSION 10g&amp;quot;
>> &gt;&gt;   FILTER &amp;quot;BEREICHKZ = '3'&amp;quot;
>> &gt;&gt; ...
>> &gt;&gt;
>> &gt;&gt; log:
>> &gt;&gt; Fri Feb 23 10:54:40 2007 - msOracleSpatialLayerGetShape():
> OracleSpatial
>> &gt;&gt; error. Error: ORA-01722: invalid number
>> &gt;&gt;  . Query statement: SELECT ***,***, GEOM FROM V_*** WHERE SST_NR
> = 0 AND
>> &gt;&gt; BEREICHKZ = '2' .Check your data statement.
>> &gt;&gt;
>> &gt;&gt; SST_NR in this case should not be null, but sth. like 'SS0023093
>> &gt;&gt;
>> &gt;&gt; Cheers
>> &gt;&gt;
>> &gt;&gt; Sebastian
>> &gt;&gt;
>> &gt;&gt; --
>> &gt;&gt; ---------------------------------------
>> &gt;&gt; WhereGroup GmbH &amp;amp; Co. KG
>> &gt;&gt; Siemensstraße 8
>> &gt;&gt; 53121 Bonn
>> &gt;&gt; Fon: +49 (0)228 / 90 90 38 - 24
>> &gt;&gt; Fax: +49 (0)228 / 90 90 38 - 11
>> &gt;&gt; mailto:sebastian.schmitz at wheregroup.com
>> &gt;&gt; http://www.wheregroup.com
>> &gt;&gt; Komplementärin:
>> &gt;&gt; WhereGroup Verwaltungs GmbH
>> &gt;&gt; vertreten durch:
>> &gt;&gt; Arnulf Christl, Olaf Knopp, Peter Stamm
>> &gt;&gt; Amtsgericht Bonn, HRB 9885
>> &gt;&gt;
>> &gt;&gt;
>> &gt;&gt;
>> WhereGroup GmbH &amp; Co. KG
>> Siemensstraße 8
>> 53121 Bonn
>> Komplementärin:
>> vertreten durch:
WhereGroup GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Komplementärin:
vertreten durch:
Siemensstraße 8
53121 Bonn
Komplementärin:
vertreten durch:
