Mapserver WMS & ArcGIS : Connnection Problem
Stefan Schwarzer
stefan.schwarzer at GRID.UNEP.CH
Fri Feb 23 08:11:36 EST 2007
Thanks... as so often just a tiny thing...
The layer finally got displayed only when I added at the LAYER level
the 'wms_extent' to '-180 -90 180 90'.
On Feb 23, 2007, at 11:56 AM, Külli Tiits wrote:
> Hi,
> I think you must add the '&' sign after the URL, like:
> http://gridca.grid.unep.ch/cgi-bin/mapserv?map=/www/geodataportal/
> htdocs/mod_map/geo_wms_y_2004.map&
> When I tried so, then I got the layers list displayed in ArcMap,
> but I still do not see anything on the map..
> But may-be it gets you further.
> Külli
> Stefan Schwarzer wrote:
>> Hi,
>> i read in a couple of posts that it is possible to connect with
>> ArcGIS 9.0 SP 3 to WMS. I can indeed open in ArcCatalog the
>> dialog box and enter the URL ( http://gridca.grid.unep.ch/cgi-bin/
>> mapserv? map=/www/geodataportal/htdocs/mod_map/
>> geo_wms_y_2004.map ) but then it says "Failed to connect to
>> server"... But if I type the address into any browser, it does
>> work fine (I mean, error message, ok, because no parameter was
>> specified...).
>> GetCapabilties:
>> htdocs/mod_map/
>> geo_wms_y_2004.map&service=wms&version=1.1.1&request=getcapabilities
>> GetMap:
>> htdocs/mod_map/
>> geo_wms_y_2004.map&service=wms&version=1.1.1&request=getmap&layers=gd
>> p_c apita,int_boundary_lines,continent_outlines
>> Any idea why this could be?
>> Thanks for any hints!
