Point Layer
Pagurek,Debbie [NCR] Debbie.Pagurek at EC.GC.CA
Fri Feb 23 10:01:54 EST 2007
What projection is your data in? Your extent parameters look like the
data are in GEOGRAPHIC (latitude/longitude) but your units is set to
METERS. If you leave your extent as is I would expect the units to be DD
(decimal degrees).
Also, you might want to set the layer STATUS to DEFAULT so that the
layer is always on while you do this testing.
Also, your IMAGEURL "C:\Inetpub\wwwroot\temp" looks incorrect - this
should be the URL that is used in the web browser e.g.
  IMAGEPATH "/ms4w/tmp/ms_tmp/"
  IMAGEURL "/ms_tmp/"
Hope this helps,
D. Pagurek
  _____
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Jandost Khoso
Sent: Friday, February 23, 2007 2:38 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Point Layer
I am facing a problem with Map server and i believe it is about a
mistake i am doing in Map File. i will be thankful if you help me to
sort that error out.
I have made a new layer which contains a lot of POI. the problem is that
whenever i zoom in more than 22.2 with units in meter that layer becomes
disappeard. i want to know how may i keep that layer visible for next
zoom ins ?!
Following is map file that i am using right now.
MAP
NAME "Zone Samples"
STATUS ON
EXTENT 51.58137 22.64441 56.37089 26.04807
SIZE 600 600
SHAPEPATH "D:\HostedWebsites\TutorialMapServerSolution\data\MapServer"
FONTSET
"D:\HostedWebsites\TutorialMapServerSolution\data\fonts\fonts.list"
UNITS METERS
WEB
IMAGEPATH "C:\Inetpub\wwwroot\temp"
END
SYMBOL
NAME "square"
TYPE ELLIPSE
FILLED TRUE
ANTIALIAS FALSE
POINTS
1 1 1 1 1 1
END
END
LAYER
NAME "POINT"
STATUS ON
DATA "Point1"
TYPE Point
CLASSITEM "LAYER"
LABELITEM "NAME"
MAXFEATURES 500
TRANSFORM TRUE
CLASS
TEXT ([NAME])
LABEL
TYPE TRUETYPE
FONT "arial"
SIZE 7
POSITION AUTO
ANGLE AUTO
#MINFEATURESIZE AUTO
COLOR 255 0 0
ANTIALIAS TRUE
PARTIALS TRUE
FORCE TRUE
#WRAP " "
END
STYLE
SYMBOL "square"
COLOR 255 0 255
OUTLINECOLOR 0 0 0
BACKGROUNDCOLOR 255 0 0
ANTIALIAS TRUE
END
END
END
END
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070223/21abe9c4/attachment.html
