WFS problem with Filter accepting by MapServer
Yewondwossen Assefa assefa at DMSOLUTIONS.CA
Mon Feb 26 17:04:42 EST 2007
There was a partial fix added in cvs. Please see bug 2034.
Yewondwossen Assefa wrote:
> There is a bug on it
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=2034. It will be fixed
> for the upcoming version (5.0)
> Later,
> Diatchkov Vitali wrote:
>> Hello!
>> The MapServer 4.8.* that we use as a WFS server has some problems with
>> GeoTools WFSDataStore at the client side. The Filter being produced by
>> GeoTool library looks like:
>> <Filter><BBOX><PropertyName>msGeometry</PropertyName><Box><coordinates
>> decimal="." cs="," ts=" ">3669974.159827543,7034913.012544877
>> 3670967.818494744,7035739.51367928</coordinates></Box></BBOX></Filter>
>> and I suppose it conforms to GML2. But MapServer does not handle
>> attributes
>> in<coordinates> tag: decimal, cs, ts. If these attributes are encoded
>> in the
>> filter XML then MapServer returns an exception that Filter is invalid
>> or not
>> supported.
>> The following filter work fine:
>> <Filter><BBOX><PropertyName>msGeometry</PropertyName><Box><coordinates>
>> Is it possible to fix the issue? Sure, it is a problem of MapServer
>> not of
>> GeoTools library because these attributes are part of spec. And the
>> combination GeoTools + MapServer is quite widespread.
>> We would like to see this problem to be fixed, don't know what is the
>> situation in the following versions of MapServer..
>> Regards ,
>> Vitali Diatchkov.
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
