PHP/MapScript getShape() failing with an index returned by getResult() - PostGIS layer
Doug B ummmmm22 at GMAIL.COM
Tue Feb 27 17:54:58 EST 2007
Turns out we did already have the 2 postgis indices created as well.  FWIW.
On 2/27/07, Doug B <ummmmm22 at gmail.com> wrote:
> On 2/27/07, Daniel Morissette <dmorissette at mapgears.com> wrote:
> > Doug B wrote:
> > > Ok.  I'll return to that. (I take it that also means that getShape()
> > > is not deprecated in PHP/MapScript?)
> > Correct.
> > > One other, possibly related, piece of information is that my postgres
> > > console window seems to be outputting "ERROR:  cursor "mycursor" does
> > > not exist" every time I execute this query.
> > Unfortunately I am not a postgis guru, but the following post suggests
> > that adding an index on OID might help:
> > http://postgis.refractions.net/pipermail/postgis-users/2004-June/004982.html
> Sounds like that may be just a performance issue, not what's actually
> preventing the data from appearing at all.  Thanks, though.  I take it
> you don't have any ideas for me on the root problem?
> > Daniel
> > Daniel Morissette
> > http://www.mapgears.com/
