SLD troubles -desperate!
Yewondwossen Assefa assefa at DMSOLUTIONS.CA
Wed Jan 3 16:44:31 EST 2007
Hi There,
  OGR is also a needed library (for geometry conversions). Is it
possible for you to test it with OGR enabled (USE_OGR flag) ? If that is
the case I will update the docs to reflect it.
Later,
Edward Fialkowski wrote:
> I have been unable to get my WMS capable MapServer to recognize an sld
> passed in through the url (SLD=http:...)
> The sld is readable, I have tested it on an example from the SLD
> documentation - i.e. written my own SLD and pointed to it from the
> example, works perfectly.
> I am totally out of ideas as to why I cannot get it to show up on my own
> server.
> I'll give as much information as i can, any help would be extremely
> appreciated.
> map file:
> MAP
>   NAME "All"
>   STATUS on
>   SIZE 800 600
>   EXTENT -2200000 -712631 3072800 3840000
>   UNITS METERS
>   SHAPEPATH "/var/www/html/mapserver
> /mapdata/"
>   IMAGECOLOR 220 220 220
>   FONTSET "/var/www/html/mapserver/mapdata/"
> WEB
>   IMAGEPATH "/var/www/html/tmp/"
>   IMAGEURL "/tmp/"
>   METADATA
>         "wms_title"     "All"
>         "wms_onlineresource"
> "http://niceguy.wustl.edu/cgi-bin/mapserv.exe
> <http://niceguy.wustl.edu/cgi-bin/mapserv.exe>?"
>         "wms_srs"       "epsg:4326"
>   END
> END
> PROJECTION
>         "init=epsg:4326"
> END
> LAYER
>   NAME NAmer_bdr
>   METADATA
>         "wms_title"     "NAmer_bdr"
>   END
>   TYPE LINE
>   STATUS on
>   DATA bound_p
>   PROJECTION
>         "init=epsg:4326"
>   END
>   CLASS
>         STYLE
>           OUTLINECOLOR 0 0 0
>         END
>   END
> END
> SLD File:
> <StyledLayerDescriptor version="1.0.0">
>   <NamedLayer>
>     <Name>NAmer_bdr</Name>
>     <UserStyle>
>       <Title>NAmer_bdr</Title>
>       <FeatureTypeStyle>
>         <Rule>
>         <LineSymbolizer>
>          <Geometry>
>            <PropertyName>center-line</PropertyName>
>          </Geometry>
>          <Stroke>
>            <CssParameter name="stroke">#00FF00</CssParameter>
>          </Stroke>
>         </LineSymbolizer>
>         </Rule>
>       </FeatureTypeStyle>
>     </UserStyle>
>   </NamedLayer>
> </StyledLayerDescriptor>
> and just in case:
> [root at niceguy mapserver-4.10.0]# ./mapserv -v
> MapServer version 4.10.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=PDF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE
> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT INPUT=EPPL7 INPUT=GDAL
> INPUT=SHAPEFILE
> Please, please any help.
> Thanks!
> -Ed
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
