Problem: MapServer 4.10.0 with postgis on Debian 3.1
Kai Behncke
kbehncke at IGF.UNI-OSNABRUECK.DE
Wed Jan 3 16:43:00 EST 2007
On Wed, 3 Jan 2007 13:02:35 -0800, Aaron Racicot wrote
> You need to add the shared object path to your ld.so.conf file and
> run ldconfig. Try adding: /usr/local/pgsql/lib to your
> /etc/ld.so.conf file and running /sbin/ldconfig as root.
Great, thank you very much!!
The MapServer is running fine now, but what I don`t understand:
I made an "updatedb" on my system and tried to find the data with
"locate libpg.so.5", but it`s not found even it is definetily there.
Hmmmmm......anyway, the MapServer is running now.
Regards, Kai
Dipl.-Geogr. Dipl.-Umweltw. Kai Behncke
Institut für Geoinformatik und Fernerkundung (IGF)
Universität Osnabrück
Kolpingstr. 7
49074 Osnabrück
Raum: 01/308
Tel.: +49 541 969-4450
E-Mail: mailto:kbehncke at igf.uni-osnabrueck.de
Web: http://www.igf.uni-osnabrueck.de
