Slow map server doing getcapabilities with 200 layers
José Ramón López joseramonlopez at GMAIL.COM
Tue Jan 9 11:07:35 EST 2007
Thanks again Bart for all.
I added this parameter to all layers, and now works fine.
2007/1/9, Bart van den Eijnden (OSGIS) <bartvde at osgis.nl>:
> Probably Oracle is calculating the boundingboxes/extents for all of your
> LAYERS, this is requested by Mapserver to produce the capabilities and is
> very time consuming/costly.
> Try setting the wms_extent METADATA for all of your LAYERs so that no
> automatic calculation of the extents will be performed.
> Best regards,
> Bart
> OSGIS, Open Source GIS
> http://www.osgis.nl
> --------- Oorspronkelijk bericht --------
> Van: José Ramón López <joseramonlopez at GMAIL.COM>
> Naar: MAPSERVER-USERS at LISTS.UMN.EDU <MAPSERVER-USERS at LISTS.UMN.EDU>
> Onderwerp: [UMN_MAPSERVER-USERS] Slow map server doing getcapabilities
> with
> 200 layers
> Datum: 09/01/07 10:03
> > Hi dear list, again.We are trying to make a wms service with MapServer.
> The number of layers is 180, wich are stored in Oracle. When we do a
> GetCapabilities request, it takes a lot of time sending the xml file.
> While
> it is sending the file, something curious happens. The process that takes
> the most of the memory of the computer is Oracle. Is there any parameter
> defined in the .map file, that makes the computer verify all the layers
> stored in the .map file?
> > When i do a getlayer like ...Request=GetMap&amp;Layers=xxx, it shows me
> fast.Does Oracle verify the layers, when we do a getcapabilities
> request?How
> i could optimize this?Thanks for all
> > -- José Ramón López
José Ramón López
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070109/ecc59b4d/attachment.html
