gdal setup with netCDF
Norman Barker
nbarker at ITTVIS.COM
Thu Jan 11 04:20:03 EST 2007
(resent since listserv doesn't like you using 'ok' as a starting
phrase!)
To build netCDF on 64 bit machines, and hence GDAL with netCDF, and thus
have netCDF support in MapServer :-)
NetCDF
ftp://ftp.unidata.ucar.edu/pub/netcdf/netcdf.tar.gz
version: netCDF-3.6.0-p1
To install netCDF, uncompress and unpack the tar file, then change to
the src directory:
gunzip netcdf-3_6_0.tar.gz
tar -xf netcdf-3_6_0.tar
cd netcdf-3_6_0/src
Edit macros.make, add -fPIC to CPPFLAGS, CFLAGS, and CXXFLAGS
Now run the usual configure, make test, make install cycle:
./configure --prefix=/usr/local
make
make install
I am not a c/c++ programmer so if I have done something criminal let me
know!
Norman
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of edfialk
Sent: 10 January 2007 18:53
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] gdal setup with netCDF
Hi! I'm trying to get GDAL configured for netCDF output (i.e. convert x
file
to netCDF).
So, I install netcdf-3.6.1 (configure, make, make install).
I configure GDAL --with-netcdf=/usr/local/src/netcdf-3.6.1
NETCDF support: yes
then i run make for GDAL, and I get:
/usr/bin/ld: /usr/local/src/netcdf-3.6.1/lib/libnetcdf.a(attr.o):
relocation
R_X86_64_32S against `a local symbol' can not be used when making a
shared
object; recompile with -fPIC
/usr/local/src/netcdf-3.6.1/lib/libnetcdf.a: could not read symbols: Bad
value
collect2: ld returned 1 exit status
make[1]: *** [libgdal.la] Error 1
make[1]: Leaving directory `/usr/local/src/gdal-1.3.2'
make: *** [check-lib] Error 2
Bad value? I got the latest netCDF from
http://www.unidata.ucar.edu/software/netcdf/...
Anyone have any ideas?
Thanks in advance!
-Ed
View this message in context:
http://www.nabble.com/gdal-setup-with-netCDF-tf2954438.html#a8263860
Sent from the Mapserver - User mailing list archive at Nabble.com.
