JOIN object usage in a mapfile {Scanned}
oven38
oven38 at VOLJA.NET
Mon Jan 15 10:21:27 EST 2007
Here is my working example ONE-TO-MANY JOIN with PostgreSQL :
LAYER
NAME "plan-var-predpis-sel"
STATUS OFF
CONNECTIONTYPE postgis
CONNECTION "user=koper password=koper dbname=gisdb host=localhost"
DATA "the_geom from loki_091"
TYPE POLYGON
JOIN
NAME testjoin
CONNECTIONTYPE postgresql
CONNECTION "user=uname password=pwd dbname=databasename host=hname"
TABLE plan_pia_data
TO pia_osn
FROM akt_id
TYPE ONE-TO-MANY
TEMPLATE "one_to_many.html"
END
CLASS
SYMBOL 'DIAGONALA_D'
SIZE 3
COLOR 255 255 0
END
TEMPLATE "one_to_many_head.html"
TOLERANCE 0
END
one_to_many_head.html :
[join_testjoin]
one_to_many.html :
<BR> FROM_ID :[akt_id]
<BR> TO_ID :[testjoin_pia_sif]
<BR> NAME :[testjoin_name]
<BR> NOTE :[testjoin_note]
Also see http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=2006
lp Alfred
Jeff McKenna wrote:
> Thanks Zoltan, that was it.
> I'll include my example on the join page.
> jeff
> Siki Zoltan wrote:
>> Hi Jeff,
>> You should refer to the column in the joined table in your template like
>> [joinname_columnname]
>> In your case it should be
>> [test_VAL]
>> Be carefull with the upper and lower case letters!
>> Zoltan
>> On Sun, 14 Jan 2007, Jeff McKenna wrote:
>>> Hello everyone,
>>> For the first time I am trying to use the mapfile JOIN object, and I
>>> can't seem to get it to work. From the mapjoin.c file I can see that
>>> DBF, CSV, PostgreSQL, and MySQL are supported. I have personally
>>> tried to view query results joined from DBF, CSV, and PostgreSQL
>>> tables unsucessfully. (my goal is to also update the sparse
>>> documentation for this also on
>>> http://mapserver.gis.umn.edu/docs/reference/mapfile/join). Here is
>>> my DBF test case:
>>> Test Environment
>>> mapserver 4.10.0
>>> windows
>>> mapfile layer
>>> LAYER
>>> NAME prov_bound
>>> TYPE POLYGON
>>> STATUS DEFAULT
>>> DATA prov
>>> CLASS
>>> NAME "Province"
>>> STYLE
>>> OUTLINECOLOR 120 120 120
>>> COLOR 255 255 0
>>> END
>>> END
>>> TEMPLATE "../htdocs/cgi-query-templates/prov.html"
>>> HEADER "../htdocs/cgi-query-templates/prov-header.html"
>>> FOOTER "../htdocs/cgi-query-templates/footer.html"
>>> JOIN
>>> NAME "test"
>>> TABLE "../data/lookup.dbf"
>>> FROM "ID"
>>> TO "IDENT"
>>> TYPE ONE-TO-ONE
>>> END
>>> END # layer
>>> ogrinfo
>>> >ogrinfo lookup.dbf lookup -summary
>>> INFO: Open of `lookup.dbf'
>>> using driver `ESRI Shapefile' successful.
>>> Layer name: lookup
>>> Geometry: None
>>> Feature Count: 12
>>> Layer SRS WKT:
>>> (unknown)
>>> IDENT: Integer (2.0)
>>> VAL: Integer (2.0)
>>> >ogrinfo prov.shp prov -summary
>>> INFO: Open of `prov.shp'
>>> Layer name: prov
>>> Geometry: Polygon
>>> Feature Count: 12
>>> Extent: (-2340603.750000, -719746.062500) - (3009430.500000,
>>> 3836605.250000)
>>> Layer SRS WKT:
>>> (unknown)
>>> Template
>>> <tr bgcolor="#EFEFEF"><td align="left">[NAME]</td><td
>>> align="left">[VAL]</td></tr>
>>> Query Results
>>> Layer: Provinces
>>> NAME VAL
>>> Ontario [VAL]
>>> Other Notes
>>> - the join seems to be happening, because if I specify false FROM/TO
>>> values errors are thrown, yet I cannot get values to appear from the
>>> [VAL] field
>>> - ID/IDENT are integer values from 1 to 12
>>> - the join works with desktop GIS packages
>>> Can someone see what I am doing wrong?
>>> thanks.
>>> jeff
