MapServer Version
Zhonghai Wang
zhonghaiw at GMAIL.COM
Mon Jan 15 10:31:12 EST 2007
yup, you are right, I have another mapserver.exe in my PATH. I've fixed it,
Thanks.
Is this mailing list not the same as the one you mentioned? seems that
windows users have their own mailing list.
Best Regards
Zhonghai
On 1/15/07, Jeff McKenna <jmckenna at dmsolutions.ca> wrote:
> It looks like you have another mapserv.exe in your PATH, is that possible?
> MS4W 2.2.1 contains MapServer 4.10.0.
> MapServer version 4.10.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=PD
> F OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE
> SUPPORTS=WMS_SERVER SUPP
> ORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
> SUPPORTS=WCS_SERVER SUPP
> ORTS=SOS_SERVER SUPPORTS=THREADS SUPPORTS=GEOS INPUT=JPEG INPUT=POSTGIS
> INPUT=OG
> R INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
> By the way, MS4W has its own mailing list for these type of
> configuration questions (join at
> http://lists.maptools.org/mailman/listinfo/ms4w-users).
> jeff
> Zhonghai Wang wrote:
> > Hi Guys,
> > today I've doenloaded the new MS4W package ms4w 2.2.1.zip here:
> > http://www.maptools.org/ms4w/index.phtml?page=downloads.html,
> > but when I use -mapserv -v to check the version, it returns:
> > MapServer version 4.8.3
> > OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF
> > SUPPORTS=WMS_SERVER SUPPO
> > SUPPORTS=WCS_SERVER SUPPO
> > RTS=THREADS SUPPORTS=GEOS INPUT=JPEG INPUT=POSTGIS INPUT=ORACLESPATIAL
> > INPUT=OGR
> > does that mean this package is not using the new MapServer 4.10.0
> > source? Should I compile it myself from source code if I want to use the
> > latest version?
> > thanks for your information.
> > Zhonghai
> Jeff McKenna
> DM Solutions Group Inc.
> http://www.dmsolutions.ca
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070115/1edf4bbd/attachment.html
