[dbox] problem in dbox resizing
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Mon Jan 22 13:26:36 EST 2007
Hi there: This is something I've been meaning to address. Let me take a
look with your code and
try and work up a simple test case on the DNR website. Might take a few
days though, I have an
offsite meeting (unfourtunately)...
Steve
>>> myunghwa Hwang <mhwang4 at UIUC.EDU> 1/19/2007 5:45:00 PM >>>
Hello, list!
I'm trying to make dbox resizable.
For that, I assigned ids to several components which should have
fixed sizes,
then I added a function for recalculating and assigning the dbox size:
function adjustMapsize() {
// test just width adjustment
var leftcol_table = document.getElementById("leftcol_table");
var tools_table = document.getElementById("tools_table");
var move_button = document.getElementById("move_button");
var scale_table = document.getElementById("scale_table");
var coords_div = document.getElementById("coords_div");
var measure_div = document.getElementById("measure_div");
var measure_toggle = document.getElementById("measure_toggle");
var new_width = document.body.offsetWidth -
(leftcol_table.offsetWidth + tools_table.offsetWidth +
move_button.offsetWidth*2);
var new_height = document.body.offsetHeight -
(scale_table.offsetHeight + move_button.offsetHeight*3 +
coords_div.offsetHeight + measure_div.offsetHeight +
measure_toggle.offsetHeight + document.getElementById
("ms_url").offsetHeight);
var anchor = document.getElementById("main");
main.width = anchor.width = new_width;
main.height = anchor.height = new_height;
main.anchor = xGetElementById("main");
ms.width = new_width;
ms.height = new_height;
Then, I added this function to onload and onresize event of window:
window.onresize = function() {
// resize map image
adjustMapsize();
xResizeTo(main.container, main.width, main.height);
main.sync();
xResizeTo(main.image, main.width, main.height);
xMoveTo(main.image, 0, 0);
xShow(main.image);
xResizeTo(main.canvas, main.width, main.height);
xMoveTo(main.canvas, 0, 0);
xClip(main.canvas, 0, main.width, main.height, 0);
xShow(main.canvas);
ms.draw();
reference.sync();
container.sync();
window.onload = function() {
// resize map image
adjustMapsize();
main.initialize();
reference.initialize();
container.initialize();
domouseclick('zoomin');
// legend setup
var legend_xml = get_content(config.dlegend_xml_executable + "?
map=" + config.mapfile + "&server=" + config.dlegend_server);
legend.initialize("legend_container", legend_xml);
legend.setHandler(DLEGEND_CLICK, ms.setLayer);
ms.setLayer('ortho', true);
legend.changeNodeStatus('ortho', true);
ms.draw();
My problem is that this solution works when I try to reduce the size
of window,
but whenever I tried to increase the window size
the size of something on the top of dbox (which consists of
container, image, canvas, and something else) does not change,
so I get white extra space on the right and bottom side of dbox.
How can I solve this problem?
Maybe someone already asked this problem, if so please let me know
which post I should check.
I hope my explanation of the problem will be understood well.
from Myunghwa Hwang
