msGetLabelSize() : Could not find/open font
Aude Allain aude.allain.ext at MAPPY.COM
Mon Jan 22 10:52:40 EST 2007
Hello,
I'm trying to display labels on my map, but I get the following error :
: msGetLabelSize(): Could not find/open font.
I defined a FONTSET FILE in the mapfile which contains font paths :
FONTSET   "../font/fontset.txt"
Content of fontset.txt :
Arial (TrueType) C:\WINDOWS\Fonts\ARIAL.TTF
And, the layer on which I want to see the labels is defined in the
mapfile :
LAYER
            NAME         " A0"
              CONNECTIONTYPE oraclespatial
            CONNECTION  "user at bd/pwd"
            DATA "GEOM FROM MN_A0 USING UNIQUE ID SRID 8307 "
            STATUS       DEFAULT
            TYPE         POLYGON
            MINSCALE       150
            MAXSCALE    500
            GROUP "Administratif"
            TOLERANCE    100
            TOLERANCEUNITS pixels
            LABELITEM "NAME"
            LABELCACHE on
            CLASS
                NAME                      "Pays - A0"
                COLOR        255 216 176
                OUTLINECOLOR 32 32 32
                TEMPLATE "ttt_query.html"
                LABEL
                         MINFEATURESIZE 1
                        MINDISTANCE 1
                        POSITION CC
                        TYPE TRUETYPE
                        FONT "Arial"
                        SIZE 12
                       ANTIALIAS TRUE
                       COLOR 0 0 0
                        OUTLINECOLOR 255 255 255
                END
            END
END # A0
The font named 'Arial' is in c:/Windows/font.
On the Web, it is said to check the Apache user or mapserver has
permission to access the font file and the ttf files. But I don't know
how to do that.
Could you hep me ?
I use :
-          windows xp
-          ms4w : php/mapscript 4.10, apache 2, php5.2
-          Oracle spatial 10g
Aude
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070122/821b6698/attachment.html
