php mapscript draw() error
James Tuthill techie at OMLET.CO.UK
Mon Jan 22 15:32:57 EST 2007
I am just starting out with php mapscript but can't work out what errors
are causing my maps not to draw().  I started out with simple maps work
just fine. However, the more complex map data that I purchase don't
appear to work. These map files renders fine with a normal mapserv.cgi -
but fails silently at the draw() stage of php mapscript.
This is the simple set of commands that I am using:
    // Create a map object
    $map_object=ms_newMapObj($map_path.$map_filename);
    // Render the map into an image object
    $map_img=$map_object->draw();
    // Save the map to an image file
    $map_img->saveImage($img_path.$img_filename);
The program fails are draw() - but there is no debug output. Can anyone
tell me how to start debugging this?
Thanks,
James
