php mapscript draw() error
Ernesto Vega ernesvega at GMAIL.COM
Mon Jan 22 16:43:37 EST 2007
you should start here:
http://mapserver.gis.umn.edu/docs/reference/mapfile/map
Look for parameter DEBUG, that allows you to turn debugging on. Be
aware of permissions. Your mapserv cgi should be allowed to write to
the path that you have to set for it.
hope it helps
Ernesto Vega
On 1/22/07, James Tuthill <techie at omlet.co.uk> wrote:
> Hi,
> I am just starting out with php mapscript but can't work out what errors
> are causing my maps not to draw().  I started out with simple maps work
> just fine. However, the more complex map data that I purchase don't
> appear to work. These map files renders fine with a normal mapserv.cgi -
> but fails silently at the draw() stage of php mapscript.
> This is the simple set of commands that I am using:
>     // Create a map object
>     $map_object=ms_newMapObj($map_path.$map_filename);
>     // Render the map into an image object
>     $map_img=$map_object->draw();
>     // Save the map to an image file
>     $map_img->saveImage($img_path.$img_filename);
> The program fails are draw() - but there is no debug output. Can anyone
> tell me how to start debugging this?
> Thanks,
> James
