EPSG conversion
John Mitchell
mitchelljj98 at GMAIL.COM
Wed Jan 24 17:30:54 EST 2007
Below is a gdalinfo dump and I need to know which of the listed EPSG values
I should use for:
LAYER
PROJECTION
"INIT=EPSG:32615"
END
Multiple EPSG codes are listed below and I am guessing that it is 32615 from
AUTHORITY["EPSG","4326"]],
Driver: GTiff/GeoTIFF
Size is 9102, 9268
Coordinate System is:
PROJCS["WGS 84 / UTM zone 15N",
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.2572235630016,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",-93],
PARAMETER["scale_factor",0.9996],
PARAMETER["false_easting",500000],
PARAMETER["false_northing",0],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]],
AUTHORITY["EPSG","32615"]]
Origin = (778859.800149363470000,3316677.809611396900000)
Pixel Size = (1.000000000000000,-1.000000000000000 )
Metadata:
AREA_OR_POINT=Area
TIFFTAG_IMAGEDESCRIPTION=Space Imaging
TIFFTAG_DATETIME=2002:12:17 22:21:17
TIFFTAG_XRESOLUTION=1
TIFFTAG_YRESOLUTION=1
TIFFTAG_RESOLUTIONUNIT=1 (unitless)
Corner Coordinates:
Upper Left ( 778859.800, 3316677.810) ( 90d 6'38.81"W, 29d56'57.43"N)
Lower Left ( 778859.800, 3307409.810) ( 90d 6'47.49"W, 29d51'56.70"N)
Upper Right ( 787961.800, 3316677.810) ( 90d 0'59.69"W, 29d56'49.87"N)
Lower Right ( 787961.800, 3307409.810) ( 90d 1'8.66"W, 29d51'49.17"N)
Center ( 783410.800, 3312043.810) ( 90d 3' 53.66"W, 29d54'23.32"N)
Band 1 Block=9102x1 Type=UInt16, ColorInterp=Red
Band 2 Block=9102x1 Type=UInt16, ColorInterp=Green
Band 3 Block=9102x1 Type=UInt16, ColorInterp=Blue
Thanks,
John J. Mitchell
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070124/532a7f39/attachment.html
