EPSG conversion
Frank Warmerdam
warmerdam at POBOX.COM
Wed Jan 24 19:02:25 EST 2007
John Mitchell wrote:
> Hi,
> Below is a gdalinfo dump and I need to know which of the listed EPSG
> values I should use for:
> LAYER
> PROJECTION
> "INIT=EPSG:32615"
> END
> Multiple EPSG codes are listed below and I am guessing that it is 32615
> from AUTHORITY["EPSG","4326"]],
John,
EPSG code 32615 is indeed the one associated with the root PROJCS
object, so that is what should be used. The others label datums,
spheroids and units.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
