WFS in uDig client
Neil Best nbest at FORESTONE.COM
Thu Jan 25 16:12:34 EST 2007
By the way, what about ArcMap?  Does anyone have it working in 9.1 or
9.2?  Is it true that you need the Data Interoperabililty Extension or
not?
Neil
> -------- Original Message --------
> Subject: WFS in uDig client
> From: Neil Best <nbest at FORESTONE.COM>
> Date: Thu, January 25, 2007 12:01 pm
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Can anyone confidently describe the status of connecting to a Mapserver WFS
> layer using uDig?  I am using the 1.1-RC8 version hot off the web and MS
> 4.99 from FWTools 1.0.7.  I can use MS as both client and server and test
> with shp2img, but when I try it from uDig nothing renders.  I can get a
> feature count, however.  Rather than provide further detail I thought I
> would ask for a sanity check if it can be expected to work or not at this
> time.  My suspicion is that there is a problem with SRS, geomtetry type, or
> some other metadata due to my ignorance.  Does uDig enforce a timeout?  I
> had to bump it up in my client map file to give my PostGIS server time to
> think.  Thanks for any tips.
> Neil
