Dbox and Raster data
william paul williampaul28 at YAHOO.COM
Fri Jan 26 02:49:21 EST 2007
Thank you again Rich
  It's was like you sad: You need to define the CLASS END, even if is empty. You just need to have CLASS defined
  William
Richard Greenwood <richard.greenwood at GMAIL.COM> wrote:
  On 1/25/07, william paul wrote:
> Hi:
> I am using Dbox, example from
> http://maps.dnr.state.mn.us/tools/dbox/
> I want to have more background layers, and each background layer is a
> raster. I have setup the metadata in the map file:
> METADATA
> # dLegend XML legend control
> dlegend_metagroups "foreground,background"
> dlegend_foreground_name "foreground:"
> dlegend_foreground_layers_and_groups "layer1,layer2"
> dlegend_background_name "background: "
> dlegend_background_layers_and_groups "raster1,raster2"
> dlegend_background_element "radio"
> dlegend_layer1_name "Layer1"
> dlegend_layer2_name "Layer2"
> dlegend_raster1_name "Raster1"
> dlegend_raster2_name "Raster2"
> END
> When I load the page I can see the legend up to Raster1 and without Raster2
> I tried to replace the layers from the background with vector data and is
> working OK, but with raster data I can see only 1 background layer
> Is it possible to use 2 or more background layers with raster data?
> Thank you in advance
> William
Yes, you can can have many background layers. I ran into the same
problem that I think you are seeing: not all of my legend was showing
up. It was syntax with the legend definitions, unfortunately I can not
remember the details. Try changing the order of the layers in the
legend, and/or removing them one at a time. This will help you find
the problem layer. And look at the class names in the layer definition
itself.
HTH,
Rich
Richard Greenwood
richard.greenwood at gmail.com
www.greenwoodmap.com
No need to miss a message. Get email on-the-go
with Yahoo! Mail for Mobile. Get started.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070125/830a9b29/attachment.html
