Does the current SDE driver in MapServer support logical and
regular expressio
Andreas Albarello
andreas.albarello at TERRITORIUMONLINE.COM
Sat Jan 27 03:44:55 EST 2007
Hong wrote:
> Then I guess I had the expression wrong then, here was the layer I had been
> trying to display with multiple classifications:
> LAYER # 9
> NAME "Census Groups"[...]
> CLASSITEM "POP2000"
> CLASS
> EXPRESSION "[POP2000] >= 0 AND [POP2000] <= 400"
> STYLE
> COLOR 112 247 38
> END
> END
Hong,
your expressions are syntactically correct, you only need to wrap them
in brackets instead of quotes, so they are actually considered as
expressions and not as strings.
EXPRESSION ([POP2000] >= 0 AND [POP2000] <= 400)
should therefore just work fine.
Best regards,
Andreas Albarello
Analysis & SW Development
Territorium Online srl/GmbH
Via Buozzi/Buozzistraße 12 - I 39100 Bolzano/Bozen
email: andreas.albarello at territoriumonline.com
web: www.territoriumonline.com
