Mapscript 4.10.0 and 4.10.2 gives segfault with Postgres 8.2
[SEC=UNCLASSIFIED]
Umberto Nicoletti
umberto.nicoletti at GMAIL.COM
Wed Jul 4 02:43:00 EDT 2007
Open a ticket at:
http://trac.osgeo.org/mapserver/
include a demo mapfile and code to reproduce the problem if you can.
We'll work on it asap.
Thanks,
Umberto
On 7/4/07, Roppola, Antti - BRS <Antti.Roppola at brs.gov.au> wrote:
> Hi all,
> We're in the process of upgrading from 4.8.1 to 4.10.2 and we are seeing
> segfaults
> when using PostGIS layers. I've had a look through the bug tracker and
> source, the main
> difference between msPOSTGISLayerRetrievePK() between 4.8.1 and 4.10.2
> appears
> to be the following (mappostgis.c revisions 1.66 to 1.77):
> * Revision 1.71 2006/05/03 22:35:41 pramsey
> * Added schema separation and search path awareness to the LayerRetrievePK.
> (towards Bug 1571)
> Does anyone know if this is a known issue? Is the schema patch likely to be
> the source of it?
> - I can usually get two or three maps before the application server dies
> completely
> - We're using the Java mapscript swig bindings
> - Postgres 8.2 with PostGIS 1.2.0
> - The segfault occurs with 4.10.0 and 4.10.2
> - I have not had a chance to see if the CGI version has the same problem
> - Reverting to 4.8.1 on the same system works fine, suggesting it's not a
> Postgres/PostGIS issue
> - Stack trace included below
> Thanks,
> Antti Roppola
> Stack: [0x6f395000,0x6f408000), sp=0x6f4033c4, free space=440k
> Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native
> code)
> C [libc.so.6+0x68055] strncpy+0x35
> C [libmapscript.so.4.10.2+0xcf5ae] msPOSTGISLayerRetrievePK+0x8e
> C [libmapscript.so.4.10.2+0xd0b18]
> C [libmapscript.so.4.10.2+0xd1694] msPOSTGISLayerWhichShapes+0xd4
> C [libmapscript.so.4.10.2+0x84f2b] msLayerWhichShapes+0x5b
> C [libmapscript.so.4.10.2+0x91c79] msDrawVectorLayer+0x1c9
> C [libmapscript.so.4.10.2+0x920da] msDrawLayer+0x8a
> C [libmapscript.so.4.10.2+0x934d1] msDrawMap+0x1d1
> C [libmapscript.so.4.10.2+0x464e5]
> Java_edu_umn_gis_mapscript_mapscriptJNI_mapObj_1draw+0x35
> j
> edu.umn.gis.mapscript.mapscriptJNI.mapObj_draw(JLedu/umn/gis/mapscript/mapObj;)J+0
> j
> edu.umn.gis.mapscript.mapObj.draw()Ledu/umn/gis/mapscript/imageObj;+5
> v ~StubRoutines::call_stub
> IMPORTANT - This message has been issued by The Department of Agriculture,
> Fisheries and Forestry (DAFF). The information transmitted is for the use of
> the intended recipient only and may contain confidential and/or legally
> privileged material. It is your responsibility to check any attachments for
> viruses and defects before opening or sending them on. Any reproduction,
> publication, communication, re-transmission, disclosure, dissemination or
> other use of the information contained in this e-mail by persons or entities
> other than the intended recipient is prohibited. The taking of any action in
> reliance upon this information by persons or entities other than the
> intended recipient is prohibited. If you have received this e-mail in error
> please notify the sender and delete all copies of this transmission together
> with any attachments. If you have received this e-mail as part of a valid
> mailing list and no longer want to receive a message such as this one advise
> the sender by return e-mail accordingly. Only e-mail correspondence which
> includes this footer, has been authorised by DAFF
