Oracle Spatial reproject geometries
Fernando Simon
fsimon at UNIVALI.BR
Thu Jul 5 12:06:58 EDT 2007
Hi Silvia,
Can you provide mor info about you layer (definition) and mapfile
(projection that you used)?
About the Oracle Spatial, the UMN Mapserver driver not execute any
transformation for the data. Just read from database and plot in
Mapserver. Are you using geodetic SRID to store your data in Oracle
DB?
Best regards.
Fernando Simon
UMN Mapserver and Oracle Spatial developer
Citando Silvia Petcu <silvia.petcu at DPRA.COM>:
> Hi all,
> I'm using an Oracle Spatial layer (polygon geometry) that is in
> decimal degrees
> (epsg: 4326), in a map that is in another projection.
> The layer geometries usually are rectangles with 4-5 vertices, when
> the map is
> draw the geometry is re-projected but the lines are straight lines
> with no
> curvature and the image is really ugly (some big trapezoids is
> the same
> image as the one generated by Spatial Advisor in Oracle if I would
> transform
> the geometry using the epsg of map).
> On the other hand if I get the same layer and converted in a shape
> file, than
> loaded into my map file, the image is re-projected nicely with
> curved lines.
> I cannot use shape files in my map, Im stuck with oracle spatial
> and I was
> wandering if there is any way to get the same image for oracle
> spatial as I get
> for shape file.
> Thank you in advance.
Univali - Webmail - http://webmail.univali.br
