trouble with attribute query
Steve Lime Steve.Lime at DNR.STATE.MN.US
Thu Jul 5 18:13:38 EDT 2007
John: Would you be so kind as to file a bug on this one. That shouldn't be the case..
  http://trac.osgeo.org/mapserver
Thanks!
Steve
>>> On 7/5/2007 at 7:20 AM, in message <468CE1F3.1000909 at al.umces.edu>, "John B.
Churchill" <jchurchill at AL.UMCES.EDU> wrote:
> I figured out the problem I was having.  It has to do with having
> underscores "_" in the text field.  If I replace my underscores with
> hyphens "-", my query works.  This seems to be an odd character for
> Mapserver to weed out but that appears to be what is happening.
> Hi All,
>      I'm having trouble executing an Attribute Query when I base the
> query (qitem) on the "filename" field in my shapefile.  I can choose any
> other field and supply the appropriate qstring and everything works fine
> but when I use the filename field I get a "no matching records" found error.
>      The text in the long string in the address bar of the browser IS
> complete and DOES match the value in the shapefile.  Perhaps the text
> values in the shapefile field are too long for MapServer or special
> characters like the "." or "-" are causing a problem ?  Can anyone
> confirm or deny either of my theories about this or point to any other
> possibilities ?
> The qstring is ...
> p016r032_09-09-1986_lt5_doc.img
> The qitem is "filename" and it is a text field.
> The entire query string in the address bar is ...
> http://localhost/cgi-bin/mapserv.exe?qlayer=landsat_4&myitem=landsat_4%2Cfilen
> ame&qstring=p016r032_09-09-1986_lt5_doc.img&map=C%3A%5Cms4w%5CApache%5Chtdocs%5Ci
> mg_browser%5Cimg_browser.map&program=%2Fcgi-bin%2Fmapserv&mode=itemnquery&qitem=f
> ilename
> The error is ...
> msQueryByAttributes(): Search returned no results. No matching record(s)
> found.
