Antwort: [UMN_MAPSERVER-USERS] Oracle Spatial reproject geometries
Benedikt Rothe
umn-ms at HYDROTEC.DE
Fri Jul 6 02:25:54 EDT 2007
Hi
> On the other hand if I get the same layer and converted in a shape file,
than
> loaded into my map file, the image is re-projected nicely with curved
lines.
No hint from me. Just a counterquestion to learn:
Which software do you use to convert Oracle-Spatial to shapefile?
Benedikt
UMN MapServer Users List <MAPSERVER-USERS at LISTS.UMN.EDU> schrieb am
04.07.2007 04:40:41:
> Hi all,
> I'm using an Oracle Spatial layer (polygon geometry) that is in
> decimal degrees
> (epsg: 4326), in a map that is in another projection.
> The layer geometries usually are rectangles with 4-5 vertices, when
> the map is
> draw the geometry is re-projected but the lines are straight lines with
no
> curvature and the image is really ugly (some big trapezoids ? is the
same
> image as the one generated by Spatial Advisor in Oracle if I would
transform
> the geometry using the epsg of map).
than
lines.
> I cannot use shape files in my map, I?m stuck with oracle spatial and I
was
> wandering if there is any way to get the same image for oracle
> spatial as I get
> for shape file.
> Thank you in advance.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070706/37ea8387/attachment.html
